Both images were already designated as PNG and even with both specified to millions for the colors it makes no difference.
Set that way in Freeway?
Okay, are the images combining with any other graphics?
Got a URL that shows the problem page?
k
Jon_Paris
(Jon Paris)
2
k
Yes - they are set that way in Freeway.
The two PNGs are being combined - but just those two.
I have experimented some more an there is a difference between the PNGs that work and the one that doesn’t.
According to “More Info” in Finder … The one that works is PNG - Color Space: RGB - Profile: Calibrated RGB Colorspace - Alpha channel: 1.
The one that doesn’t work is simply PNG - Color Space: RGB - Alpha channel: 0
I guess the Alpha channel has something to do with it but …
