[Pro] Pop up messages????
What action can I use to create a small message/quick view.
Similar to this page HTC United States when you rolllover the images, yet using no flash.
This is one example using JQuery http://www.deltadesign.co/fw_examples/jquery-tooltip.html
Okay, so how exactly did you do that? It looks great.
Revisit that example for some instructions.
Caution - there are actually 2 methods on that page. There is a link to the Unitip method to get the files required and the Read Me - probably as well to stick to it.
