I have a site that I created in FW6 that I want to “mobilise” in FW7. I’ve published the site, but when I Preview a page, all I get is a white (ie empty) window.
I’m probably going to rebuild the whole site from the ground up, taking the move to FW7 to be an opportunity to do a bit of tidying up, but it would be useful to know if there’s any particular reason that a site converted from FW6 to 7 won’t Preview…
Just to clarify, are you previewing in Freeway or in a browser? If it’s just in Freeway, try previewing in browser to see if that works. A couple of things to try that might help if you’re still having no luck:
Go to the Page menu and choose Force republish and try previewing again.
If that doesn’t work, go to the File menu and holding Control, select Publish Everything.
Cheers,
Force Republish (Page) - still doesn’t preview in FW7
Publish Everything - still no Preview in FW7
I don’t know if this means anything, but after trying these last 2, if I try and preview one of the non-index pages, a filled dot appears next to index in the left hand site pane.
I tried opening up another of my older (smaller) sites, and that Previewed ok, so it’s something specific about this site - maybe one of the several plugins I’m using?
As I said, I am going to redesign the layout of this site, so I don’t need to get this version working in FW7. Obviously it would be useful for you to know what’s going wrong though. Should I email you the site? (Or perhaps the whole folder, via Dropbox?)
Hmm. I got the same problem when I copied over the elements of the index page into a clean template, so I started removing elements to see if one of them was causing the problem.
As soon as I removed a frame containing an .swf file everything works ok.
I’ve been wanting to replace the two .swf movies on the site for a while, so now’s the time!
Hah. It’s a time to clean up your Flash feature! It’d be great if you could stick it up on dropbox and send it into support(a)softpress.com for someone to have a look at.
