You have a fundamental error on some of your pages. I’m pretty sure it’s not because of Carousel, I don’t see any instances of Carousel on the pages where the error appears.
Here’s a way to try to fix it.
First, do a Save As, and give yourself a new version of the document to work with. Then you can always drop back to the other one if this branch doesn’t work somehow.
Next, in the Document Setup dialog, create a new Site Folder, so this site doesn’t share anything with the previous version.
Now, go through each page in the site and remove all instances of the various Scripty, Protaculous, and FX Actions. Be sure to note (copy and paste into a scratch text document) any custom coding such as those you might have added in the Protaculous Function Body editors. Make certain you find every single instance of each Action. You may leave all the extra elements lying around on the pages, as you’ll be coming right back and adding everything back in a moment.
Publish once.
Finally, go back through the pages and build up your effects again. For any Carousels, apply the Carousel, Carousel Pane, and other navigation functions and re-configure them to their original settings.
Publish again, and test in your target browsers. Everything should be working now.
On Nov 4, 2011, at 12:10 PM, Jay wrote:
Hi,
I’ve just reloaded the site with the action not working in 5.5 if this helps. www.creativedge.org
Jason
