I’m not sure what I should be seeing. I am quite certain that these
Actions work, and that they work together without conflict. I would
like you to try something, and to do this before you try to fix your
current page. (Don’t do another thing to this page before you do this.)
Make a new document in Freeway. Add a single page to it, and make it
very tall. Draw three HTML boxes on that page, spaced at regular
intervals down the page from top to bottom. Give each one of them a
different color. By default, Freeway will name these item1, item2, and
item3. Scroll back to the top of the page, and draw a fourth HTML box.
Double-click inside it, and add the following text:
one | two | three
Highlight each word in turn, and use the Hyperlink dialog (Apple-K) to
add the correct link to each word, using the External tab:
#item1 #item2 #item3
Preview, and make sure that when you click on each link, the page
snaps down to the correct colored box.
Now duplicate the HTML box containing these links twice, and move the
copies down the page so there is one near each of the color boxes.
Finally, apply SmoothScroll to the page. Test again in a browser.
Now that you have a working instance of SmoothScroll on one page, you
can add Carousel to the same page.
Move down the screen to your second colored HTML box. Use that box as
the starting point for your Carousel effect. Duplicate it, then apply
Carousel Pane to the copy (and give it a different color). Apply
Carousel to the original, and set an auto-glide interval if you like.
Create tabs or buttons to navigate the effect.
Test in a browser again, and see that the carousel effect works as
designed. Click on the smooth-scroll anchor links, and yes, those work
as well.
Now, your current page still doesn’t work, but we’ve ruled out the
individual Actions being the cause of that per se. First thing I
would do is put your page on a diet. It’s enormous, takes ages to
load, and that can’t be helping things at all. Next, I would remove
all the Actions from the page, and publish, and see if the anchors
work as you expect. (Yes, you will have a bunch of extra panes hanging
out in random places, but in order for the smooth scroll effect to
work, you must have actual working anchor links from one part of the
page to another.)
Fix the anchors so they accurately snap the page down to the desired
spot. Then add the SmoothScroll Action, as above, and test that effect
in isolation. Once that part works, then you can start adding the
Carousel back in by applying the relevant Actions to the various parts
of the effect. If that causes it to break the smooth scroll effect,
then step back and undo what you just did until it works again. See if
you can isolate what step makes the difference.
On Jul 22, 2011, at 3:24 AM, Shammer wrote:
Walter,
I’ve done all you’ve suggested but no success.
I updated the site, can you inspect it?
Also, I used the Scripty Lightbox action and all of a sudden it
stopped working
(I had to switch to the second version (not my
fav though…)
Can you help me out?
