I’m trying to make a rollover button that branches into more options, so in its normal state it has an image, and beside it a general text heading. When you rollover either of those, the picture would brighten, and the general text be replaced by two more specific options, either of which would change individually with a rollover or click.
I was trying to do this with the normal rollover action, but it doesn’t seem sophisticated enough for the number of options required. Is there an action for this?
You can use images within a CSS Menu item - this would give you the different ‘levels’ you want.
Thanks for your suggestion, I’m going to have a look and see if I can figure out what you mean.
If you have an online example of what you are trying to achieve we can probably offer more directed suggestions.
