[Pro] problem in rollover action
Hello. I need to make a simple rollover with two graphic items. Im using rollover action, but if I unchecked the layer box in general tab of inspector, the graphics are sent to back, so you cant see them, because they are behind other elements in the page.
Is any other way to make the rollover?
Alternate rollover method
http://www.deltadesign.co/fw_examples/rollover.html
You know my oldest (and a trillion times done) recommend?
Activate the element view in the sidebar. The sidebar is enabling you to navigate through the items and makes you another aspect clear:
Did I name my item134 etc. in a useful or a semantic way?
If you are sure, that eg. item258 is my button-hover, mark it in the sidebar and send it to foreground or hit enter. I’m sure you’ll be able to work much quicker than now - even with “hidden” items.
This could look like:
DeltaDave, it works properly with this other method. Thanks a lot.
Thomas, I know this way of working with elements in the side bar, but if you don´t set the item as a layer, its impossible to take it in front of other elements. The unlayered item goes direct to back. I had a look in the forum before asking, and found lots of people asking for the same, but couldnt find an answer.
Thanks a lot
