[Pro] Problem moving FWP website?
I just tried moving an updated FWP website from my development server to my client’s live server and everything transferred okay, save the CSS menus, which ended up looking like text listings, except for the Perch enabled pages.
Unfortunately, I had to take the update down because I didn’t want to inconvenience my client. I’ve never had that happen before. What do I need to check?
Okay, I placed the updated website on another domain I own so you can see what’s happening. The Perch database has been disabled for safety’s sake. View any of the pages that are NOT Perch enabled and the CSS menu fails. http://gorcb.com/about.html
But the same code on my development server works fine:
http://wmp.idealynx.com/about.html
Any ideas on why this is happening?
Okay, I think I figured it out. The #fwNav1 code is missing from some of the LIVE pages, but I don’t know why. Simply dragging and dropping files shouldn’t do that. This is very weird.
The #fwNav1 code was commented out. I just corrected it on one of the LIVE pages, but I’m still perplexed as to why that is happening.
And why the development server copy is working, when it shouldn’t be.
You’ve fixed this already, I think. It looks fine here.
I did, but I had to manually fix the code using TextWrangler. That shouldn’t happen. For some reason, FWP is inserting comment marks around the CSS menu code it’s generating. Check out this other page that I haven’t fixed:
http://gorcb.com/about/map.html
Then, check out the very same page on my development server, where the comment marks exists, but for whatever reason they’re being ignored:
http://wmp.idealynx.com/about/map.html
Is this the GD server up to its tricks again?
Unfortunately, yes. I really wish I wasn’t under contract with them. Upon further review of the code, I noticed this error message:
[an error occurred while processing this directive]
What the heck? I updated the website to HTML 5. I wonder if that’s part of the problem.
It is this that GD server doesn’t like
<!--#fwNav1
The server thinks the code is commented out
This is the same problem Justin had: http://www.freewaytalk.net/thread/view/128055
I’m going to try that solution and when my contract with GoDaddy expires they are GONE!
Try using External Stylesheets - either through an action or in the Doc Setup preferences.
What sort of Contract did you set up with them?
I do use them for Domain Name Management but wouldn’t touch them for hosting so have never had to consider their “contracts”
I think it’s like a 2-year hosted domain contract.
Check you haven’t a comment that looks like
<!--# Some Comment-->
before this include, if you have then change it to
<!-- Some Comment -->
See if that fixes the problem.
HTH
I’m inserting a comment in the HMTL Markup , but nothing with a # symbol. Here’s the only code I’m inserting:
<!-- Begin Menu drop shadow code -->
<style type="text/css">
.sub {
-webkit-box-shadow: #000000 3px 3px 5px;
-moz-box-shadow: #000000 3px 3px 5px;
ul.sub, ul.sub li.fwLastChild, ul.sub li.fwLastChild a {
-webkit-border-bottom-right-radius: 5px;
-webkit-border-bottom-left-radius: 5px;
-moz-border-radius-bottomright: 5px;
-moz-border-radius-bottomleft: 5px;
</style>
<!-- End Menu drop shadow code -->
I think Apache will think it is a SSI tag, if it where
<!-- #fwNav1
and not
<!--#fwNav1
then I guess it should be OK, if there is whitespace it should not be read as an SSI tag by apache.
<!--#fwNav1
That doesn’t mean you have to host there. Go ahead and buy/register all the domains you like from them (although I wouldn’t just on general principles) but host anywhere else you like. You only have to bite your tongue and visit their “control” panel once in a great while – to point your domains at your host of choice.
Yes, but I already spent several hundred dollars so I can hosts multiple client sites off of my domain. I need to wait until that expires to move to another provider.
Maybe I am wrong on the whitespace stopping this <!-- # being picked up as a SSI tag by apache:
Found this from a post on this on the internet back from 2008
http://the-stickman.com/2008/03/
HTH
<!-- #fwNav1
and not
<!--#fwNav1
<!--#fwNav1
