… unfortunately there is no automatic balancing here in Coda world.
Maybe I’m not following what “balancing” is, but Coda 2 does close open
tags for me. If there is an unclosed tag and I type the < or </ keys, Coda
auto-fills the necessary tag ending.
And I should add, as with style brackets, when closing any tag Coda 2
briefly hi-lites the tag pairs.
That’s true, but in Kelly’s case he needs to find the missing closing tags in a preexisting doc.
Coda
Technically yes. But (at least in my experience, though I have been wrong before) it will also insert a doc type etc. which would break Kelly’s Perch template which is just a partial, no need for the default page structure in his case.
In that case, what about using the “PHP & Web Toolkit” plugin, with the
Tidy HTML or CSS feature… will that close up his malformed tags?
Yes, part of the problem was I was coding with Text Wrangle,r so as Ernie pointed out it should keep me from doing stupid stuff, like the mess I created earlier.
Class styles always start with a period (.) e.g., .classStyle ID > styles start with a hash/pound (#) e.g., #idStyle
In FW, if it’s just a class then add the name (e.g., classStyle) > in the Name field and FW will add the leading period (.) for
you. If it’s an ID style then put name (e.g., #idStyle) in the
Tag field and make sure the Name field is empty.
Thanks Todd. I need to start writing some of this stuff down.
If you’re hand-coding, you can use any structural element you like. In Freeway, the easiest thing of all is the table. But if you want a good semantic structure, not just a physical one with limited semantic relevance, try an ordered list or an unordered list. And use the label tag! Here’s a hand-coded example of a form that uses both to great effect:
The point of the ordered list is that it reinforces the tab order of the elements. Note also how I’m using the :first-child pseudo-class to set the size and text alignment on the first label in each row, or any input without a preceding label, so there’s a strong visual “spine” to the form.
On May 14, 2013, at 4:45 PM, RavenManiac wrote:
Okay, next problem. How do I line my input fields up? Should I put these in a table or is there a better coding solution?
I’m not sure if I can use the label tag since Perch uses it’s on proprietary tag.
It’s important to realize that Perch’s “proprietary” tags are converted into normal HTML on output. These extended tags are processed by the PHP interpreter before the page is served. If you are curious, you can view source in your browser while viewing the page as it is served from your Web server. But this template language is fairly consistent and one of the nice features of Perch from an “integration with other tools” standpoint.
Walter, this worked great on the form. However, because my CSS Menu is also a list it negative impacted that. How can I fix the menu?
