[Pro] Problem with WebYep Loop
I have set up the web yep loop element on a couple different sites and I keep running into the same problem. Everything works initially, but after a short time the controls for the loop stop working. I am referring to the controls that move the element up and down, turn an element on or off, and add/delete an element.
I can still edit photos and text, but I can not move, delete or add new elements.
Some of the loops I am having this problem with can be found here:
http://www.theguitaroutlet.com/products/acousticguitars.php
http://www.theguitaroutlet.com/products/archtop-guitars.php
http://www.theguitaroutlet.com/products/electricguitars.php
When I create a new page with a loop on it, at first it works fine, but very soon the control just stop working. It is the oddest thing! This is happening on more than one site for me.
Thank you in advance to anyone that can offer some help on this issue. Thanks!
actionsdev mailing list
Hmmm - I am not the expert, but could it be (probably) having to do with your table-construction? I tend to say that building your construction in proper DIVs should do the game - but uahh I may fail. It looks like the controls are hidden (overlaid) by the previous loop. But if there is no further reaction on this, I’d recommend to give Max a quick mail. He’s the one that could shed the true light in it. But it is worth to try to wrap it as a test in a simple div (html-item). Make sure the CSS Button is switched on.
If you want to use a table, you may need to insert the loop code manually, using the Table Inspector’s Extend button to place the loop outside of a template table row (TR). That way you can repeat rows until you run out of content.
Hi peter could you send me your freeway artwork. That way I can see what may be causing the problem.
speak soon max
Hi Max,
I just sent an email to the address you have listed on your site.
Thanks!
Peter
Hi peter I just sent it back to you with the artwork amended.
All it needed was for you to move the loop start and loop end items outside the actually inflow table and that was it from that point on you loop the whole table rather than rows within it.
All the best Max
Thank You Max!
I just made those changes live on my server and the loop is working fine now.
Pete
