This displays differently in the ‘page’ setting of Freeway and in Safari. In the former, it extends several centimetres down past the end of the text; in Safari, it extends to the bottom of the text; in Explorer it only reaches to 2cm or so above the bottom of the text. Why this discrepancy? Any advice gratefully received.
The way to keep the line the same height of the text is to add the line as a border to the side of the HTML container that holds the text and remove the height attribute - that way it will grow/shrink with the height of the text.
Thanks David – been offline hence this slightly delayed response. I created the line by drawing it as a graphic box 1px wide down the side of the text. I’ll do what you suggest and see how that works. Many thanks for that.
I now have another problem. I have several HTML text boxes on a page. They look fine at the default viewing size, but when I resize the text in the browser, they all begin overlapping. Is there an easy way to fix this? Any help greatly appreciated. The page with the issue is here:
