[Pro] Problems uploading Hype animation
I am having an awful time trying to get my Hype animation to work and I am about to give this up entirely.I have read the posts, I have read the tutorials and I still am unable to pull this off successfully.I am probably doing something very simple and very stupid but I sure could do with some guidance.
The animation in question is of course on the animation page on my site, which shows just a blank area where the animation should be.
If someone could take a look at it and help me figure out what is wrong I would appreciate it.
Limey
http://www.petesdogpawtraits.com
Which is where?
BTW - with larger screen sizes your BG image tiles and duplicates your Nav buttons
Sorry,it is on the Winston page…the one with no image showing.
I’ll check the background tiling, the site is still under construction and there is still quite a lot of fine tuning to do.
Which is where?
There is a problem with a missing script
undefined_hype_generated_script.js - Failed to load resource: the server responded with a status of 404 (Not Found)
I haven’t used Hype in a long time. Might be worth re-exporting the Hype stuff into a new folder and re-import the new files into FW
This also might help Moving to Hype 1.6
It is important that you create a folder within FW that has the same name as the output Hype Resources folder ie yourproject.hyperesources and within that create an html page and place an instance of the Hype Support Action on it.
The actual page that will have the Hype animation on it can be on any page of your site and should not be within that newly created resources folder.
Thanks D
I will look into it and see if I can fix the problem.In all my searches It never occurred to me to check out information on 1.6.At a brief glance it looks as if there might be new and valuable information contained in this link which is more comprehensive than the ones I was checking in previous Hype 2 uploading solutions.
I finally had time to look at this animation problem I was having and these suggestions of yours really helped a lot. My animation is actually up and running now, it was quick and easy this time round.The extra link supplied here (concerning Hype1.6) covered a few extra points that the Hype 2 tutorials didn’t and made the whole process much easier to understand from start to finish.
It might help others who are having Hype animation issues to have always have information about this link for Hype1.6 when attempting to use the Hype 2 information.
Thanks for the help I appreciate it.
Limey
