I just upgraded my Mac and also upgraded to Freeway 5.5. Now, I can’t customize CSS Menus. I’ve never had a problem with it in the past, but I can’t changed the color of the text and changes I make to the master show they are being made throughout, but the other sites don’t seem to update. Even when you go into the individual setting for the CSS menu on each page, they match the master, but the output is before the change was made. I tried refreshing…no luck. Please help.
Didn’t work. The hover and current page background is working as it should now. But the font is still not changing colors when hovered over or as the current page as I have selected. Any ideas? I set them up as links using the bottom quick select.
Did you apply any styling at all to the link text within the CSS Menus
box on the screen? When you create this list of links, you must keep
the text entirely plain, even if you don’t like the way that looks.
You apply the style (if any is needed) using the Action palette or the
Link Style segment of the Inspector.
