I am trying to use two action - ScriptyLightbox.fwactionb and Mootools Suite.fwaction -
Booth actions are in the folder:/application support/freeway5 - but when I try to use one of them they dont appear in the Freeway5Pro - /Items/action
Do I make a mistake when I install the Actions ?
I wonder also when I look in the folder: /application support/freeway5 - I just see to actions: ScriptyLightbox.fwactionb and Mootools Suite.fwaction -
Where are all the other Actions installed
Sorry for the grammar - English is not my mother tongue
Thanks in advance for any help.
Greetings from Copenhagen - Frank
Scripty and Moo will not work together on the same page. But this
should not stop the Actions from appearing in the list of available
Actions. Do you have an element on your page selected when you pull
down the Item menu? If not, then that’s normal – only Page Actions
are available to you when no items are selected on the page.
Items/action
Thanks for the reply - Walther. And yes I have the element selected when I pull down the Action menu.
And no I dont try to use both Actions on the same page.
But I got a message that say something about the settings is wrong - other time something is not found.
Sorry for the bad information
If you can tell us what the error is or post a screenshot somewhere we can probably help some more
There are 3 places where actions are stored the one you suggest above - user/library/applicationsupport/fw5/actions and also HD/library/applicationsupport/fw5/actions - the difference being that the folder user/etc is only available to a particular user where HD/library is available to all users.
There are also actions stored within the FW application bundle itself. If you right click the FW app and show package contents there are actions within the Shared Support folder (the FW bundled ones)
