You’re seeing a problem with the ScriptyAccordion Action. This can happen some times – Freeway loses track of the files that an Action wants to publish, and it publishes empty links rather than the files. Here’s what I see in the of your page:
<script src="" type="text/javascript">
</script>
</script>
Those two should be pointing to prototype.js and scriptaculous.js, respectively.
First trick is to create a new Site Folder, or delete everything in your current one (and I mean the folder on your Mac where Freeway publishes the site, not the folder on your server where you upload it). Look in the Document Setup dialog, click on the Site Folder button and use the Finder New File dialog to create a new folder for your site. Publish after this step, and see if the problem is gone.
Second trick is to use the Edit / Resources dialog, press Resample All, Publish again, and see if that resolves it.
Third trick is to hold down the Control key and choose File / Publish Everything (hidden menu option) to force-rebuild the site.
Fourth trick is to note the settings on the item in the Actions palette (write them down), then remove the ScriptyAccordion Action from the item, publish once (don’t upload) and then re-apply the Action, re-set the Actions palette from your notes, and publish again.
One of those (or maybe two or three of those) will sort this out. It’s not you, or your efforts to follow the directions. It’s a software bug.
On Oct 25, 2013, at 6:41 AM, Roger Appelmans wrote:
Hi there,
I am new to this forum and my English isn’t a 100%…so forgive me
I bought a ready mad template you see here : http://www.photographer.graphicid.nl/page3.1.html
to only thing i did was edit some text but i have seemed to loose a function here:
I write down all the settings but i hope someone recognizes the problem and know were the answer is at.
http://www.delahaye.nl/dev/vragen.html
