Just wondering if anyone out there uses A2 Web hosting and is able to publish your site from within freeway pro 6.
I signed up for this host provide because of there advertisement saying they have easy freeway publishing
" There are no headaches or frustration getting your site up and running thanks to our easy to follow Freeway publishing instructions."
This is not so they don’t have any publishing instructions at all for freeway pro.
If anyone can get this to work please let me know the correct setting for the document setup/ upload in freeway pro
Thanks for any help…
I’ve only used FW a couple times with A2 and that was some time ago. Do you have the Passive checkbox enabled in the FW settings? Are you trying to upload via SFTP? If so, what port number are you using?
