I have a question about a form, if you fill in the form and press send the form will be send by email. Now I want a confirmation that the mail was send. I know you can do it with a redirect but I was wondering if it was possible to get a popup sign.
From my understanding, if you set the script up to have redirect to a confirmation page (such as a thank you page) this will let you know if the script went through successfully.
There should be an option in the script for a redirect to page…
I have used a script called formtoemail. Two versions, reg and pro. When I was learning about forms the support team at Softpress sent me this:
When people have issues with forms if, for some reason, they can’t use the PHP Feedback Form Action (or perhaps it doesn’t do exactly as they want), then we normally point people at FormsToGo from BeboSoft http://www.bebosoft.com/products/formstogo/overview/. The Support people at BeboSoft are great, and they are very familiar with Freeway - so it would be a good idea to have a word with them to see if they can foresee any issues with using GoDaddy (I’m sure they will have had experience of any GoDaddy issues, if any).
They have a dedicated movie tutorial at http://formstogo.stationv.com/danjaskarvideotu.html which shows how to set up a FormsToGo form in Freeway which makes the process all the easier. I should point out that Dan Jasker’s video tutorials link to his blog is out of date (he now specializes in selling commercial Freeway tutorial screencasts from his site at http://www.danjasker.com/store/screencasts/.
Great support options out there. You should be able to get up and running without any problems once you mess with it a bit.
Hi,
PHP easiForm has this option along with many others, set it up and see
if it does what you want, your host will need to be ioncube friendly
and Go Daddy is if you host there. http://www.easibase.com/freeway/freewayactions.php
HTH
On Sep 14, 2010, at 8:38 PM, david Verbruggen wrote:
Hi,
