I would like to upgrade to 5.5 but I would like to know how it will affect any sites I currently have in 5.4.3? Will there be any issues opening/editing these files?
No issues there but recommended that after opening in 5.5 you create a new site folder and publish into that and then check carefully everything works before uploading. Remember that FW automatically creates a file that can be opened by the previous version of FW so that you can always go back.
