[Pro] Question re accordion for Walter
Hi Walter I’ve used your accordion with arrows example and code to create my own and all working great but I wanted to ask how I would use a custom image in place of the unicode arrows?
Dave
http://scripty.walterdavisstudio.com/accordion-with-disclosure-triangles.html
That’s relatively easy. Generated content can just be empty boxes – you can set the content attribute to ‘’ (two single-quotes) and that gives you no text content. Then give the box some shape with width and height, and finally, set a background image on it. That will get you exactly what you want. If you use the background-size attribute, then you can make your images double-size, and shrink them to fit, resulting in “Retina” resolution, so it looks as sharp as the Unicode trick.
#item1 h2:after {
  content: '';
  position: absolute;
  width: 16px;
  height: 16px;
  left: 6px;
  top: 0px;
  background-image: url(path/to/closed.png);
  background-position: center center;
  background-size: contain;
#item1 h2.open:after {
  background-image: url(path/to/open.png);
Dave
#item1 h2:after {
  content: '';
  position: absolute;
  width: 16px;
  height: 16px;
  left: 6px;
  top: 0px;
Thanks I’ll give that a try later, much appreciated.
