Hi - I have a possible job coming up but has a task I’ve never done before - on a webpage there will be a question with 3 possible answers one being correct - the user must select the correct answer to be able to proceed to another page - giving a wrong answer will lead to a incorrect answer page…
Was wondering is there a simple way to achieve this? I know the hidden URL could be a way but not sure how this would would work giving its a multiple answer question so would presume radio buttons could/would be used
Any pointers would be great! Thanks
J
How ‘secure’ does this have to be?
If not an issue then I think the answer is a bit of Javascript in the head of the page that changes the Post to part of the submission depending on which radio button is selected.
I have something similar somewhere - I will have a look.
Great thanks, No security needed.
Thats seems pretty cool - Ill give that a try - do ya have the how to?
If you wait 25 secs on that page - all will be revealed.
BTW - this is all Walter’s work! Thanks Walter.
