The QuickEmail routines on several of my sites, using different templates, have stopped working. My first guess is that it has something to do with the javascript library, but I am not sure.
The emails simply never arrive (nor in the spam filter).
I have tried republishing the sites and I have tried with various email addresses. Has anyone seen this or have an answer? I have no idea how many emails I may have missed on any number of sites, since eI only discovered this when someone said they had been trying to contact me.
Presumably it could also be server settings, but again I have no idea what would have changed.
Check with your hosting provider and see if there are specific requirements for an email address when used with sendmail - are you using a site specific email address? You might have to.
Other than that spam settings are a likely cause.
The problem being that it once worked, and now doesn’t. This makes it extra tough to debug. Some of the sites have site specific email addresses, some don’t. None work.
I am running my own servers (OSX Server) and I don’t have any specific requirements for send mail, and PHP is definitely turned on and supported.
I was hoping someone had seen and conquered this issue.
