[Pro] random background with full background?
Hi, Is it possible to have a random background generated, with full background? I see the two actions but do they work together? If not is there a way to do it?
J
The Random Background Action[1] will choose a background image and/or a color on a page at random when the page loads. These are the same options you would get in Freeway when you set the background for your page. Further, you can apply the Action directly to a layered object on your page, and it will get the same (random) treatment. Each page element that you apply the Action to will get its own random choice, which can lead to some highly unpredictable color combinations!
  1. ActionsForge - The Complete Repository of Freeway Actions
J
Hi but in the background settings there isnt a full page image option? As in stretch the image so it stays full to the page window, see background here…
http://www.thekiteacademy.com/test/index.html
heres the full page action:
http://actionsforge.com/projects/view/75-full-background-image
That’s true, but then that wouldn’t be a background image at all.
Those don’t have dimensions, they float behind anything else you put
on the page, etc. Any image – by definition – that you can define as
having a scale or dimension is not a background image.
Now you can certainly place an image at the back of the layer order,
and you can set it’s width to 100% and use some JavaScript tricks to
make its height stay in lock-step with the width while filling the
browser screen. But that is still not a background image at all.
Hi Justin,
Here’s a link to an action I wrote for someone and in the end it was
never used. It may be of some use to you.
http://www.freewayactions.com/test/background-slideshow/
Rather than gathering dust in the back of my action’s drawer I think
it’s best I share it.
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
Thanks Tim! Ill def be trying that out. Thanks Waltd, understood.
Still learning to code but will try and figure out
J
On 16 Apr 2010, 6:02 pm, Tim Plumb wrote:
Hi Justin,
Hi Tim
Do you have to have the images for the background in any type of format e.g. tiff, jpg, png etc or any fixed size.
Regards
Lee
Hi Lee,
These are all 800 x 600 pixel PNGs but your images can be any web
ready file format (JPGs, PNGs, GIFs, etc) or a mixture of them. The
action will scale them proportionally to fit the browser window so you
will be faced with a trade off between quality (small images will
pixelate when scaled up) and image size (my 10 images make this sample
page a whopping 6.5MBs!).
Express & Pro.
Spam.
Tim
Safari 4.0.5 doesn’t give me any scroll bars when viewing your example so on a Macbook I cannot get down to the bottom of the page.
Mmm, I’ll look at this when I get a second.
On 17 Apr 2010, at 11:41, DeltaDave wrote:
Tim
Express & Pro.
Spam.
Hi Tim,
I see you updated the background slideshow. works great now. You build it for me, but we didn’t get it right at that time. But i’ve downloaded it an tested it again.
But also I don’t get the scrollbars. The rest works fine now, so if you could manage the scrollbar problem, I will still be glad to pay you the 150 dollar we agreed.
