Has anyone successfully converted an existing Freeway Pro website to a responsive site?
I’m trying to determine if it’s feasible to convert an existing inline designed website to responsive or if it make amore sense to do a complete rebuild.
Unless your existing site is already completely inline and flexible, then
complete rebuild.
If you have improved your skills and would build differently than what you
did before, then definitely rebuild. Don’t shy away because you think the
work is hard… challenge yourself to improve the design as well. If you are
still so in love with your previous performance, then maybe hold off until
you have learned a few more things and can look at your former work and say
“I can do better than that”.
responsive site?
rebuild.
… very common, I hate my site already. This is a good trait sometimes - always wanting to improve and never settling for ‘good enough’. I’m sure when i’ve finished my new responsive site after a while I’ll look back and see ways to improve it.
No matter how good you get, i’f you’re not nervous before you take to the stage then it doesn’t mean enough to you…
