Hi all,
I upgraded to 5.5 and rushed to make every page Relative Page Layout (test site) and nothing works.
I have read thru the different posts and now I know less than when started searching, to me very conflicting.
The Action automatically groups all your items up into sections, a bit like a table but using CSS for the positioning. Take a look in the screenshot below at what happens when the Action does this (the two red items at the bottom of the page), the groups overlap each other. Because overlapping isn’t good (ok, some might work but for best results we advise trying to avoid it) you should try moving either both the items at the bottom down further, or moving the graphic at the bottom left up so it gets grouped with the items above it, or down so it doesn’t cause an overlap.
Also, manually grouping logically connected elements such as these may also help the layout.
Failing that, send your document in to support and we’ll take a look at what’s happening.
On 1 Oct 2010, at 16:21, kitesurfer3 wrote:
Hi all,
