I have two different Websites I’m working on. Both are using a query slideOut Tab feature. On the “Wren Harrington Site” the tabs works great and as does the responsive CSS Menu. (“Buy Album” tab on right)
However, on the Iron Horse Cigar Depot site, using the exact same query, the Responsive Css Menu does not work. (tabs on the left)
Anyone who can help me sleuth this would be saving me from going crazy. Please Help!
Is there a Pure CSS way to do this with a click toggle that I could use instead.
I can’t find the other thread where you reposted this, but the reason why this is broken is you are using a version of lightbox.js that is written for Prototype.js, and yet everything else in that page is using jQuery. (Confusingly, you have two different versions and copies of jQuery loaded into the same page.)
tutorials mailing list
If so, there are two slide shows on the home page, but that is the only page with two slide shows. I’m not sure if that would explain the two versions of jQuery…
The other possibility that I can think of is this site: http://plasticvilleusa.org. That one makes heavy use of the lightbox2 action, which I believe is jQuery.
Thanks for emailing!
Doty
I responded to this last night via email. I thought you were talking to me directly. The tread was lost and my email filters aren’t working quite correctly since the change to the new FreewayTalk changes. Please disregard above.
