Is it possible to have an image as the overlay in a responsive menu on mobile instead of just a color.
Anyone have some mark up for this?
Billy
Billy
Sure, why not? Just look at the produced code via the Inspect Element option (present in both Firefox and Safari), you’ll find the appropriate div to target via your general stylesheet; probably it called something like ‘fwNavContainer1’
So in order to apply a background-image to your menu, just create a Tag-style called ‘.fwNavContainer1’ (without the quotes) and just approach it like a normal DIV … background-image, colour, whatever …
Richard
Thanks Richard that worked. I had tried that before but I left out the dot before the name of the div. I was trying to use #.
Billy
You are right sir, I funked up there ![]()
You didn’t screw it up, I did.
Hey I have another question.
I purchased the Freeway templates and I’m adding my content to the template “Retro’d”. I want to place some images into the portfolio area of the template, but as background images. Can you make background images in divs flexible (responsive) much like background-size for a page background?
Billy
Yes. background-size:cover (or fill) will do what you are looking for here. A background can be applied to any object on the page except actual text.
I purchased the Freeway templates and I’m adding my content to the template “Retro’d”. I want to place some images into the portfolio area of the template, but as background images. Can you make background images in divs flexible (responsive) much like background-size for a page background?Billy
I tried putting an image in the background in the inspector palate and applying background-size: cover. Doesn’t work. It works with Pass through graphics.
What am I doing wrong?
Scroll to the bottom of this page and look at the image under “Photography”
Billy
Try background-size: contain
yes that worked.
Thank you so much.
Billy
