[Pro] Responsive Css Menu
I can’t get my responsive menu to open at breakpoint 667px.
Anyone?
http://drnsb.com
I am seeing a javascript error - probably a conflict with lightbox.js included with WebYep
Probably because you have jQuery on there as well.
It so happens you are loading 2 versions of jQuery - never a good thing never mind the javascript library conflicts when using Script/Protaculous on the same page.
In the section (version 1.11)
Near the end of the section. (version 1.5)
Keep the newer version.
The newer is 1.11?
Billy
So I removed the scriptaculous stuff and the old version of query but it still doesn’t work.
Also every time I upload to the server Freeway is writing this form file over and over -FW_SendForm_index_contact39.php. I’m up to 39.
Billy
Just figured that out. Go Daddy was not checked.
Billy
Go into the Site folder and delete all versions of -FW_SendForm_index_contact?? - at the next upload FW will start again and only produce 1 and delete all the other versions from the server.
And yes 1.11 is the newer version.
Your error probably comes from the load order of your (many) scripts.
Try adding
Before the jQuery no conflict but you may have to play around with this - not sure which rely on jQuery!
where do I add this? ? or ?
Billy
I removed all scripts one by one to see who may be the culprit but that did not fix the issue.
Lightbox was completely removed from the server.
Very odd.
Billy
Before the jQuery no conflict in Page head
I assume that you haven’t updated the page online?
Still plenty of js up there.
Yes I have but I restored all the files as well
Can I see the online example where you have removed the jquery and it still doesn’t work?
