[Pro] Responsive Header/Graphic
Hi,
my name is Steffen, I’m from Germany and I started rebuilding my website with Freeway 7 (Pro) last week.
I bought freeway because of it’s responsive features, and that’s the point, I don’t get the header responsive…
I have a .png file, imported it as a passthtough graphic and want to set it 5% distance to the left page corner and 5% to the right and a fixed distance to the top of 25px. So that it will fit to the page at every size.
If I export it the header is always a way to big and not in the browser frame.
Where is my mistake?
Sorry for that simple question, but I tried it for a few hours with no result.
I’m looking forward to getting your answers,
Steffen
Steffen, we are having a similar problem, can’t find any help in FW reference manual appendices or online. Nothing addresses “responsive graphics” that I can find. Have looked and looked at Inspector for the graphic; no way to set percentages or flexible width that I can find.
Posted a similar question a few hrs before you did, still no replies to mine, either.
Sure hope someone can show some mercy to baffled FW users who are trying to get graphics to work right.
Sally&Matt, have you studied the Freeway video “Getting started with responsive web design in Freeway”. I learned a lot by examining the inspector panels in this video. Find it at the Freeway support page.
I saw the video a few times before I went to this forum :wink:
Just at the moment I solved my problem nearly. Now there is only one “jump” from default size (960px) to tablet where the header doesn’t fit the width… I have exactly the same settings at the header in every breakpoint!
These are:
Measurements;
H. Align: Left (%)
V. Align: Top
Width: Fixed (%)
Height: Flexible
Dimensions;
Position:
5% to the left
50px to the top
Size:
Width: 90%
max. width: 100%
So why is there a smooth transform from tablet to landscape and not from default to tablet? Maybe it’s something with the respnsive menu? This starts at tablet size?
Thanks, Rick, will go watch again :slight_smile:
I captured a short screen video of the problem I have, you can take a look at it here: http://youtu.be/gzY-za4yVnI
Okay, now I’m thoroughly baffled.
Stopped tutorial video at Inspector panel for graphic.
Set up test page in FW 7.01.1.
My Inspector panel for graphic does not look like the one in the video.
I cannot set Align to “Left”; “Left” is not an option from my drop down menu (I do have “Float Left”).
I cannot type anything into the box where the tutorial’s 100% width value is entered; it will not allow me to type there.
Tried same test in Version 7. Same thing.
Screen shot showing side-by-side Inspector panels of tutorial and test file here: Imgur: The magic of the Internet
Thanks for any advice, and sorry to mix questions on your post, Steffen.
Sorry typo in that; my test was done in FW 7.0.1, not 7.01.1 (and also in 7.0)
haha okay, mine is like in the video…
so if someone would take look on my problem here: http://youtu.be/gzY-za4yVnI
HOLY SMOKES, got it! You were right, Rick, it was in the video, though glossed over in about a literal second.
Now everyone can ignore my question :slight_smile: THANK YOU for pointing me to the video again!
Steffen, I will now go take a look at yours just in case it’s related. Not that I’m any sort of expert or anything, but maybe two non-expert heads can figure it out (Nein, ich bin ein Dummkopf :wink: ) Good luck!
