Hi all
I’m working on a modal pop-up, see example URL (pop-up appears after approx 3 seconds), and all working OK so far except that on mobile screens I can’t get the pop-up to sit in the middle of the screen horizontally, I guess because % measurements aren’t being used? Is there something I can add to the script that will make it more responsive at mobile screen sizes?
Dave
http://www.stundesign.co.uk/footsteps/Pop/index.html
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
Where did you get this particular script from Dave
Likes: 1 ❤
Try this on your mobile
http://www.deltadesign.co/DD/modaltest.html
Likes: 1 ❤
Hi Dave
Script was adapted from the one found here:
Dave
Hi Dave
Here’s a screenshot of your link from my iPhone, it’s still not sitting in the middle of the screen.
https://dl.dropboxusercontent.com/u/595516/IMG_1425.PNG
I can adjust the script so it does, but then it’s off on desktop screens???
Dave
This is what I see from your link
At least mine is OK vertically!
I will have a look and see if there is a margin issue.
And if you look at the demo that goes along with the script you will see it isn’t correctly centered on mobile either.
Likes: 1 ❤
I think the issue is that the total width (including padding) of 300 is not being taken into account. Nominally 280px.
Try it without that padding and see what you get.
Likes: 1 ❤
Yep you got it! Adjusted the padding to just be at the bottom of the window and added padding to the text div to compensate and it’s working fine now:
https://dl.dropboxusercontent.com/u/595516/File%2026-05-2016%2C%2009%2011%2033.png
Top notch advice as always.
