I’ve been working on a FW7 template (Esperanto) and have customized part of it, so far, but I have noticed that on iPhone or phone or any tablet in vertical position, the menu does not show the open icon as it was supposed to. At first I though it was because or the open icon color that was too light and I changed, but I compared to the original one and it wasn’t the problem. I compared both CSS menu/responsive settings and they are the same.
What am I doing wrong?
Here’s the link of the page:
http://www.plusartgraphics.com/test/newplusart
And here’s another link with a screenshot of the iphone and Android screen:
http://www.plusartgraphics.com/test/newplusart/Example/
Marcus
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
…by the way, I realized that this also happens in Chrome or Firefox in a desktop machine.
Likes: 1 ❤
Probably because you are using a psd
…/Resources/menu-1-aluminum.psd’
Use a png, jpeg or gif
Likes: 1 ❤
It worked.
Thanks, David.
Marcus
Likes: 1 ❤
And for those that might follow - psd is not a web ready format and should not be used as a background image (which it is when used as the CSS Mobile Menu icon)
FW will convert imported psd files under normal circumstances.
BTW - you might want to look at the image file sizes in your slideshow as some of them are pretty close to 1Mb and very slow to load.
Likes: 1 ❤
That PSD icon was part of the “Esperanto” template… That’s why I didn’t realize it was the problem.
Thanks, David
Marcus
Likes: 1 ❤
David, you mean the main slideshow on “home” right?
Yes, they are too heavy. I’ll reduce the size of the images too.
Thanks again,
Marcus
Likes: 1 ❤
Optimized! I tested on a very slow internet and loaded in 2 seconds.
Thanks, David
Likes: 1 ❤
