I’m using Caleb’s ‘fourWrapperAlt’ modules in a responsive layout. I want to make the 4 floating boxes that have the ‘Box Sizing’ action applied to them, ‘Rollover’ buttons. Can’t seem to do this unless I remove the ‘Box Sizing’ action.
Is there a workaround for this – or is it some serious coding?
Huh, I must admit that I’ve never tried using the Box Sizing action in combination with a rollover.
However, it should be very easy to manually do what the Box Sizing action does. Right-click on each of the columns, and go to “Extended”. In the <div style> tab, add these entries:
Name
Value
width
23.75%
-webkit-box-sizing
border-box
-moz-box-sizing
border-box
box-sizing
border-box
The width value assumes that you have not modified the widths of the columns in any way. If you have, you will need to crack open the filename_override.css file that the Box Sizing action builds and get the correct values from there.
‘Panel’ meaning box containing picture and text.
I would like to have a tint cover the whole box (and all it contains) when the mouse hovers over it. Clicking the mouse over it will then link thru to another page. So a ‘panel’ with all the attributes of a button!
I just don’t seem to content myself with the easy way…
You can wrap a link around an HTML box in HTML5, so just use the HTML 5 Block Link Action to add a link to your box containing both text and picture. You will need to do some hand-styling to get the text in the box to look right (it will inherit a generic link appearance from the page), and if you want the block to have a rollover effect, you’ll need to style that as well.
On May 19, 2014, at 6:05 PM, Nik Andrew wrote:
Thomas,
http://www.promains.com.au
see ‘Product Overview’ block under the Technical Documents heading (tho these link to a pdf).
I am trying to basically replicate this site in a responsive format.
One other strange thing:
I am unable to find the standard ‘Rollover’ action within Freeway 6. I have the CSS 3 Rollover action but not the original as supplied with 5.5.
Does it no longer exist or should I be reinstalling 6?
Ok, figured the missing action thing out – can only be applied to graphic items – doh!
It looks very much as tho I will have to make all these panels static rather than responsive – not as pretty but workable.
Sorry Dave, can’t upload as the workings only exist on my computer at the moment.
I don’t require the pdf/download ro in any event, tho I would have to be able to link to another page.
I will probably have to settle for ro text instead – much, much simpler.
I do like your blue ro however, would certainly be the more striking option.
Similarly, I’m trying to create a stacked graphic with rollover so one image appears over the other during a mouse rollover.
Using Caleb’s responsive layouts, when I try to stack one graphic (using imported pass-thru images) over another to create a rollover, I am unable to do so … one graphic gets placed to the side of the other.
I’m trying something similar - a pass-through graphic with a graphic box (colored at 75%) opacity on top of it. I’d like the colored box to be visible on rollover. The images are stacked, but aren’t showing up in the Actions pallet when the rollover is applied to the top image.
My images are not responsive - the only way I could figure out how to make the overlay stick with the parent image was to have them both fixed, but I think it looks good.
