[Pro] Responsive tables
is there any way to have tables to be responsive in freeway.
Can you be a bit moire specific about your use case. An online example of your layout would help.
There are many ways that you can add CSS to your FW page to create Responsiveness just not so easy using FW in its ‘out of the box’ mode.
Hi Dave
I built a whole website using tables and it is greatermonctondahliaclub.ca. I would like the pics which are links to other sites, etc to be as they are now, vertical down the page not horizontal like I have seen responsive sites.
That is a totally different issue.
Tables for layout and Data Tables (to which I was referring) are worlds apart.
Making a complete site built with a Table Layout responsive will require a rebuild - there is no easy fix I am afraid.
If you are using FW7 the advantage you have is that you can do it one page at a time - it doesn’t all have to be done at once.
First thing you want to do is build a new Responsive Master page as it appears that the construction of most of your pages is the same.
How many pages are there actually in your site? It looks like only 7 or 8. You would also be as well to make your membership application a proper web form.
Do you also have some Flash content in there?
You might want to run the spell checker over it while you are at it.
FOR GENERAL CLUB INFORMAITON
FOR CLUB ACTIVITES
