I have designed a responsive website in freeway. On my iPhone it does not fit the whole screen. It is displaying slightly too narrow. I have set it to 320px. How do I fix this problem? Many Thanks, Nx
All content of http://www.nicolecalder.com/Mulberrylodge/ has fixed dimensions where they should have flexible (percentage based) dimensions. That’s why stuff won’t scale.
This has mainly google reasons but as well responsive ones, cause it enables you to create a responsive menu for the tablet/mobile world.
Basically, there are lot of items in your workspace where I’m not sure what role they play. Another smart thing is to name your items. It helps you to navigate through your workspace and enables you to better handle them.
Keep in mind, that showcase isn’t really a responsive tool so far. You’d perhaps do better to create a gallery in Exhibeo.
I’m still not sure how much I like responsive websites, I kind of prefer the alternative mobile website for mobiles, however I still want to get my head around the new Freeway breakpoints and am having some problems that I think might help make me that decision.
A simple question really, lets say i make an item
in the default page tab: some Html text with the phone number above the email address left justified and placed to the left hand top of the page, just how I want it.
Now on the 320 page tab I want this in the centre of the page, with the text centred.
Freeway allows the move but not the style change, is there a way around this?
What I was really hoping for was that Freeway would let me make any changes I want at the given breakpoints without affecting the original default page. Am I missing something?
When selected the 320 tab you can add the style(change) as an extended option to the div containing that text, like this:
Select DIV
Hit Cmd+Alt+X for Extended …
Select
tab
Add: (name) text-align / (value) center
Done
Freeway should honor this and center your text when passing the 320px viewport. I’ve done exactly this on this project: http://beta.ontwerpzaam.nl/kiramek/index.html. Only I start centering the text around the 768px breakpoint up until the 480px, passed the 480px another change was made.
I get the preference for (separate) mobile sites/layout, but the thing is … you don’t need to. When you got your ‘default’ layout done properly (inline layout that is), keeping in mind what you want to realize for the mobile layouts … the layout will be a lot easier to adjust for the different breakpoints (Media types).
