I have eight Rollovers and Targets. How do I get a one given target to be visible whenever the pointer leaves the rollovers?
If you have the bottom one of your pile set to be visible all the time then the others will appear over the top of it and it will still be there when you roll off.
Thanks Dave,
I appreciate your answer.
My question is how do I set that target to be visible all the time?
If you are following the tutorial then you ensure that the bottom image is ticked in all the areas of the action palette ie in each column
So ticked in normal, image1, image2 etc.
