I don’t know what the heck I’m doing wrong. I’m trying to create a roll over button with two pieces of graphic text (one with a outer blur one without). I create the graphic text, align them, group them, and this is where things go wrong. The tutorial video says to click on the group name and apply the action. When I do this the two states don’t appear in the action window. The only way I can get them both to appear is to click on the bottom state in the group. But when I put an action on that it doesn’t work. Any tips? This is driving me crazy. I’ve watch the tutorial a dozen times and I can’t get it to work.
Make sure the blue CSS button is on in the tool bar then:
Draw and align your two image graphics
Group your two images
Click in the middle of the group
Apply the Rollover Action.
If I remember rightly, when you are using FW Express or a non-layered
(table) based layout, you do not need to group the image graphics.
HTH Colin
get it to work.
THANK YOU. Man I know this was a dumb thing but it was driving me crazy. I don’t remember “Make sure Css is turned on” being in the vids. Thanks so much
