No, the click state is really a concatenation of the mousedown and
mouseup events. If you click down and then release the mouse button
within the bounds of the element you’re observing, then a click is
fired.
You would need a different action to make an effect fire on the
Mousedown and Mouseup events separately. And at the moment, that
Action[1] is pretty user-unfriendly, because it requires you to know
the JavaScript necessary to create your own effect.
On May 13, 2010, at 4:36 PM, Paul wrote:
Hi Walter,
have tried that just now as a non link, and it does show though does
not return the the original state. Should when the button is pressed
show the click state until you release it? just like the form send
button on the contact page? Have put the test button in the middle
of the home page(anyone viewing link this later, the temporary link will be removed
here once solved)Will post it to another site here: http://www.concretecreative.co.nz/testpage1/
