Rollover is a different event. If you roll over an image, the rollover
event fires. If you roll off of the image, then a different event
fires. The event firing is what allows the JavaScript function to
notice that you’ve done something, and adjust the page to suit.
On May 13, 2010, at 4:57 PM, Paul wrote:
Ok, thanks. What about submit rollover image that seems to work on
the form
