[Pro] Rollover causes jump to top of page
I have set up Rollovers that have an alt. image for the mouseover and a Show/Hide Layer when you click on it.
But, when you click on it, it jumps you to the top of the page. There is nothing up there in that group. The navigation is in a different group. What am I missing?
http://sedonabody.org/beta/clothing.html
(Please keep in mind that this site is not yet public - thx)
What I really want to create can be found here: http://www.gaiam.com/product/id/1033063.do
but I’ve tried everything, so will be satisfied if I can just keep the visitor where I want them on the page. There will be a whole page of clothing using these actions.
Thanks in advance for any help, Laura
What do I have to click on to see this?
BTW the effect is done in Flash on the linked page but you could use Zoomify http://www.zoomify.com/ or similar. I think there is a FW example for Zoomify somewhere - maybe on the SP site.
Click on “Size & Fit” or “Description”
Yea…I knew it was in flash…I’m always pushing the envelope.
I’ll check out zoomify, too.
thanks, Laura
I now understand the confusion - I have updated the page since my first post. It’s only the “Size & Fit” or “Description” that causes the page to jump to the top.
This will be a bigger problem as I add more products.
L
Hmmm - I am seeing your problem - but only if I have scrolled the page down first.
Without the page scrolled it doesn’t do it - in Safari at least!
Why do you need an onClick on the picture?
Have you set any anchors on the page?
No anchors on this page - only links in the secondary Navigation at the top goes to anchors on other pages.
Also happens in FireFox & IE
If what you mean by onClick - so the size chart shows up and then toggels with the Description. This is the first time I’ve used an onClick.
Would it help for me to list how I have the rollovers & layers set up?
L
I found the answer. Works perfectly. Thanks for your input David.
http://www.softpress.com/kb/questions/121/Prevent+Rollovers+with+no+Links+from+Jumping+to+the+Top+of+the+Page
