I have setup a couple of rollovers on a page. And a couple of rollovers are further down the page.
There is no attached links to them, just rollover “mouseover” actions. But if you do click on the button or any of the buttons, then it makes the page jump back up to the top. Which is annoying. As i would imagine some users would try and click on these rollover buttons.
Any ideas of how i can stop this? It would be much appreciated.
Select a rollover, open the Hyperlink dialog and in the External tab enter the following into the large central field:
javascript:return false
Repeat that for each of your rollovers.
On 30 Mar 2010, at 15:17, Phil Moreton wrote:
Hi all, first post.
