[Pro] Rollover click
Hi guys!
This is the deal. First I would like you to check the image on the link.
Imagine that A B C 1 2 3 4 are buttons, or images clickable.
My goal is to configure freeway so that when i click image A only images 1 2 3 get visible and image 4 hide.
Then if i click image B the inverse happens. Image 4 gets visible and images 1 2 3 hidden.
In the end if i click image C all images 1 2 3 4 get visible.
IMAGES A B C ARE ALWAYS VISIBLE.
Any idea?
Tks
http://www.kbolo.net76.net/example.html
While this is doable - http://www.deltadesign.co/fw_examples/fwactions/click-to-show.html
This may not be exactly what you want.
Can you explain the logic behind this as there may be more required.
The problem is that there are many more click permutations possible.
THANKS!
Yes you’re almost there.
Just 3 problems:
  • From default all the images number should be ON
  • After clicking on C images 1 2 3 4 go ON but for some reason I cannot perform any other actions on buttons A and B unless I press C again
  • If I made two clicks on A or B they invert their actions
You didn’t say that - you said “when i click image A only images 1 2 3 get visible and image 4 hide”
Agreed - that is why I asked “can you explain the logic behind this as there may be more required.”
See my answer to 1
Is it possible for you to rearrange the example to see if you get what i want, and by the way explain who did you do it?
No - not with the FW actions Rollover and Target Show/Hide Layer
It would need to be hand coded - that is why I asked what the logic behind it was.
And if instead of hide we just change the image cor or something?
I don’t know what you mean!
This is a hand coded javascript version
http://www.deltadesign.co/fw_examples/walts_scripts/click-selector.html
If you are a codeaphobe then rethink your strategy.
All credit for this is due to Walter as I have only modified code that he originated.
