hi all,
i’m (still) working on my site and stumbled upon this problem i cant fix…
first: a preview of the site: http://shizihou.nl/new_site/kungfu.html
at the bottom of the site you can see 4 circles. each circle is used as a button for either 1 of the 4 pages shown. Works as a charm, but this is what i want
There are 2 images for each button: an empty circle and a filled circle. I want the 1th filled circle to be visible when the 1th page is shown. the 2nd when the 2nd page is shown etc. (Just as in: iMac 24" - Apple (NL))
I don’t know how to do this. Can somebody help me?
Thanx a lot!
Hi Wouter,
you need to create two additional tag-styles, something like
How to create you find additional infos on:
http://www.freewaytalk.net/thread/view/73694#m_73970
This is an example I didi in the past using exactly that method:
Hope this helps you out.
Hi Thomas,
thanx for your quick reply. I tried it and it works!
you can see it here: http://shizihou.nl/new_site/kungfu.html
gr, Wouter
Excellent.
One thing that you should be careful of on your page is how it looks with the text size increased.
In Safari - under the View Menu - there is an option to ‘Zoom Text Only’ if you select that and then visit your page and Cmd+ a couple of times to increase the text size you can get an idea of how your page(s) will look to other visitors who may want to make your text more readable. 10px is quite small.
I am not sure if you have your text containers set to Overflow:Hidden or not or whether it is because it is contained in a Carousel - but some visitors will not be able to read it all. Also bear in mind that Windoze boxes tend to render text larger than on your Mac.
Hi David,
I noticed that too indeed, but thanks for mentioning it. I actually want the size of the caroussel to get bigger when the text is outside the container. Or actually that the entire site gets bigger. But for as far as i’ve seen and read on the forum that is really hard to acchieve.
Thanks again for all the help!
