i’d like to have a loop-photo gallery which works like a rollover : let’s say 5 images aligned, and when i click on the first one,il switches to 2nd one which appears instead
and again when i click on the 2nd one, it switches to the 3rd one and so on, until the the end of the loop.
i tried with the rollover action but i can’t do it ofr more than 2 :any help? thank you,francesca
If you don’t mind a page reload, you could do this quite easily using the Link to Page Action. The way that works is you apply it to an object on the page, and then select whether it should link “forward” or “back”. These directions relate to the other pages in the same folder as that page. So to make your gallery, you would put all of the other gallery pages in a folder within Freeway’s Site pane. Once you have set this up, you can change the order of pages just by dragging the pages around in the Site pane. On the last page, you could either make a notice: “You have reached the end” or loop around to the beginning.
