[Pro] Rollover in Carousel Tabs
Hey folks!
Has anyone found a way to apply a rollover to a carousel tab? I have tried a variety of ways and no joy so far.
TIA
-ss
It works fine here. Pay attention to the order of operations: Make
your rollover group, and configure your rollover to work correctly.
Then apply the Carousel Tab Action to the finished rollover.
On Mar 13, 2009, at 4:52 PM, Solutions Etcetera wrote:
Hey folks!
Hmmm…
Ok… I remove all carousel actions.
I group the rollovers for each tab, and test. They work.
I now assign the carousel action to the group of html boxes.
And then I assign the carousel tab action to each of the rollover groups… and then group the tab (rollover) groups, and the html box group.
No joy. Rollovers don’t work, and while the tabs show the right html box, no carousel slide occurs.
Any idea what I am missing?
Could you post a link to the page? Also, could you tell me what
version of Carousel Tabs and Carousel you are using? (They each have a
different version number.)
On Mar 13, 2009, at 6:29 PM, Solutions Etcetera wrote:
Hmmm…
box group.
Carousel = 0.8.1b
CarouselTab = 0.5.1b
site= http://aboutpollockpines.com/caratest/
I appreciate your willingness to have a look.
-ss
That’s what it is, then. I fixed this bug in the transition to 0.8.2
and 0.5.2. Download the latest and install it over the current
version. Re-publish. It should just work.
On Mar 13, 2009, at 7:00 PM, Solutions Etcetera wrote:
Carousel = 0.8.1b
-ss
Indeed it does.
Thanks so much.
-ss
