In other words, it is a one time button. It is the yellow block on the page. I went thru all the different parameters.
thanks.
SH
http://intuitionusa.com/freeway/3d_renderings.html
What settings have you got on it/them
Thanks however I found a simple way to do with just loading one image. I use the rollover action and in the first parameter attach the rollover image. Quick.
I did point you to that method in one of your other posts on the subject.
