I’m attempting to create a button with a Rollover Action.
The button consists of three graphic items (for Normal, MouseOver, and Clicked) and an HTML item (the text).
If I have the four items Grouped and select
Item>Actions
then Rollover does not appear in the Actions menu. If, however, I Ungroup the four, then re-Group them but without the HTML item, then Rollover appears in the Action menu (which has, in addition, grown much longer). However, creating the rollover without the text item creates a problem: presumably because the text isn’t part of the rollover, the Action stops when the arrow is over the text, which takes up 90% of the button).
What incredibly obvious thing am I missing?
