Can someone please tell me how can I create rollover text link without the underline under the link. I would like to have the link text one color and mouse over another color then a third color when in that link page.
I try the insert action “Text Roller” and there is nothing in the action window to make it a link, change color and no underline.
in that link page.
Make sure nothing is selected, then click the second icon in the
Inspector, open the Link section, and use the controls there.
You can set how the different states of a link will be coloured, and
by clicking those (admittedly non-helpful) ‘U’ buttons you can
control the underline state of links. White means it is left to the
browser, pale grey means underlines are off for this page, and darker
grey means they’re explicitly on. Or so I believe.
This works at the page level so it will affect all text links on that
page. If that’s acceptable then don’t bother using an action to
achieve this.
achieve this.
k
Absolutely Keith and an example like this shows how versatile FW is in that there are often many ways to skin the proverbial.
