What’s the best way to create a rollover graphic button that fades through transition.
I’ve tried Transition fx, CSS rollover action and css3 rollover action and can get it to work. The closest was using transition fx but the top image doesn’t toggle back to it’s normal state on mouse off.
I was hoping for a simple solution as there seems to be so many other transition/target options.
