SLIDESHOW with Pause/Play rollover graphic (no actual text, its all graphic images) I wish to have an extra 4th rollover state and Freeway support says its not available in Pro. ActionForge have an action called Rollover_60.fwaction, has anyone used it successfully, I can find no info about it.
1.Normal state - Grey button
2.Mouseover state - Grey button with green light
3.Paused state - Grey button with red light
4.Normal return to play state - Grey button
Rollover 60 (and its other “60” kin, are just hacked versions of the built-in Freeway Actions. There is nothing different about them except the sheer number of form elements in their interfaces.
Not going to solve my problem then? Anyone have comments how this 4th rollover state might be easily achieved. I am moving over from GoLive to Freeway and this was relatively easy in GoLive.
I am now committed to Freeway so there is no going back to outdated Golive just for this rollover element. However, I have used the Sequence Timer/click60 actions to extend a slideshow with good results.
