I structured the rollovers and targets by starting left to right with column 1 first rollover then moving to column 2 for the next rollover and continued from left column to right column of rollovers ending with the last rollover and target in column 2.
The last rollover target in column 2, always is the target which appears first when viewed on the web? I want the first rollover target in column 1 to appear when the Folds Series page appears.
In the Action Target Show/Hide Settings for the Image that is currently visible, ensure that the setting is for “Initially” is “Sticky”. All the remaining images should have the “Sticky” setting except for the Image that you want to be first viewed, the setting for “Initially” should be “Visible”.
The Initially setting for all except the first image should be “Hidden”. The Restore setting for all images including the first image should be sticky.
The problem I’m having is that I can set all the images to be “sticky” even with my obsessive and repetitive attempts, I cannot find “hidden” anywhere in the Actions menu.
It shows the Actions Palette for the Target Show/Hide Images for the different graphics below. The one on the left is the setting I use for the image that is shown first. The image on the left is the setting for all the remaining images.
