[Pro] RPL Problem
I applied the Relative Page Layout action to this webpage and it works on the area where the text is but the rest of the page is messed up when you make the text bigger.
OK sorry here is the link I forgot to put on there http://sunshineambassadors-dance.org/
Applying the Remove From RPL Action to the large graphic item that’s underlapping all the other items (the one with the sun in it) will fix this.
Some things to note:
Generally if something isn’t working it’s down to overlapping items
If you have a graphic or some other static item at the very top of a design then it doesn’t need to be part of the page layout. This is because it doesn’t increase in size like HTML text meaning it won’t affect items below it.
Hope this helps,
HI Nate
Is there not a ‘Sunshine’ missing from the beginning of the Welcome paragraph?
Yes thank you I fixed the missing word problem. I still cant get the RPL to
work right. The sun stays still but the other graphics move down the page.
On Mar 15, 2011 3:17 AM, “DeltaDave” email@hidden wrote:
HI Nate
paragraph?
Have you uploaded it? The item “SunshineSuncleareyes” is still being added to the relative page layout. If you select it and apply the Remove From RPL Action to it then it should all work. Failing that, get in touch with our support team and they’ll be able to help you out:
HI Nate
paragraph?
List Options | FreewayTalk
